zerosleeping
Regular
See the option with HDMI is that you can use the monitor as a TV by using a HD DTH connection. Of course audio output will have to go via
audio out to separate speakers but this is one additional feature to have.
You can get a nice HD PCI-e card and connect to the monitor using either HDMI or DVI-D for a digital experience.
My setup is connected via DVI to a Geforce 8500GT.
Btw the Dynamic Contrast Ratio (DCR) doesn't matter. What you should be looking at is the actual brightness of the panel
The BenQ G2420HD has 300 nits (cd/m2) and GL2450HD is 250 nits. The response time of GL2450 is 5ms. 2420HD is 2ms G2G.
The GL2250HM has a 2ms reponse time (faster than 5ms) this is crucial if you are a gamer, has a lower dot pitch. All in all
if you don't need the higher screen real estate (21.5" v/s 24") no harm in going for the 2250HM.
I am not getting any younger and already have an older Acer 22" AL2216W, so the 21.5" would have been a downgrade for me.
The difference is approx Rs. 2000/- between the 21.5" and 24" so I would advise to go for a higher sized panel if you can
afford it.
This is the post that prompted me to go for the BenQ http://www.erodov.com/forums/samsung-p2350-vs-benq-g2420hd-one-buy/29739.html#post415821
afford it.
