I am happy to reply u. As of present i m using Pinnacle PCTV Tuner Tuner Pro which is Anolog
Tv Tuner card along with FM & remote. PCTV has the best software to run PC TV Application. Quality is A1+ & i m running this Tv Tuner on my Pc since more than 8years now so you can imagine how wonderful this card is which i purchased that time at just around 3k. I run
Tata Sky on my card.
In future i would consider an upgrade to a new TV Tuner card. I hav full trust on pinnacle but the present lineup are not that great in feature which i want. But i suggest you buy what i recomend you. It should have the following listed:
1. It should support both DVB-T as well as Analog signals (dvb-t for plugging tatasky cable directly to tv tuner card or use seperate antenna for the same & analog for using cable or tatasky with set top box connection)
2. It should have build in encoder - this will reduce the cpu usage by way big margin specially using
tata sky. Helps in viewing picture smoothly if there r resource hungry app running in the background
3. PCIe x1 interface only - dont go for PCI interface, choose pcie only and not even USB
4. FM, Recording, Remote - depends on ur choice
There r many tv tuner cards to choose from in the market
Rememeber that TATA Sky is DVB-T MPEG-2 reception so buy a tv tuner based on this config. Everyone in thier replies simply talked abt ports and not talking the technology behind tata sky... Also note that TATA Sky has gone HD and i am planning to buy HD set top box to improve quality of my TV. :clap:
If you got any other query then contact me on my email id as i wont look at this forum anymore. :notallowed:
how u add tata sky cable directly to ypur pinnacle card ???
