dude, listen, im using the same plan. its a really good plan. u should get speed of 256kBps, ie your speed can go to a max of 32 kbps. mine goes up to abt 31, 32. if u dont get speeds in da higher 20's (use limewire to see or amazing down software), then u should call the mtnl ppl. they might take sum time to come but theyll fix it. don get rid of dis plan. it awesome. and mtnl isnt as bad as ppl say. only their service is poor.good luck.
