Trouble with Connection!! critical
  • Thread starter Thread starter rhapshody
  • Replies Replies 6
  • Views Views 1,425
rhapshody
BSNL-UL900
Hey all, i got a issue i need ur help on..i have a Dataone connect: plan UL900Modem/Router : UT-300R2U since i took my connection 5 weeks ago.. i have serious issue's with connection and routing..my speed though 256kbps.. goes to a max of 80-120kbps..d'load speed 8-14kbps... ive got my wiring re-done right from the DP... my system's and phone's are new... no technical glitch with my equipment..but i dunno how i manage to get such pathetic speed...:wall:would like your help on it.. SG server's.. which people generally get a ping of 80-190.. i get a ping of 700!! :OAny kind of help will be appreciated :)Thanks !!Rahul
Welcome to Broadbandforum.in1.To start with. Did you try the SG TCP/IP optimiser. Try default values.2 Try FireFox browser.3.Exit all unused programs appearing in Taskbar ( except AV/Firewall)4.What is the SNR and attn data shown in modem ? How far you are from the Exchange ?on your feedback. =====>>>>more !
1.To start with. Did you try the SG TCP/IP optimiser. Try default values.2 Try FireFox browser.3.Exit all unused programs appearing in Taskbar ( except AV/Firewall)4.What is the SNR and attn data shown in modem ? How far you are from the Exchange ? 1> could you guide me a il on the tcp/ip optimiser thingy?..2>i already use firefox..3> my OS is newly installed.. doesnt have over 3 icons in taskbar.. only antivirus, sound n b'band4> SNR data?.. wats that?... my place is 4kms from exchange
I appreciate the way, you have posted the reply. in the 2nd post of yours.
Just type the number !
or high light the text copy paste add
in the beginning and [/quote ( add ])
1. Since you mentioned SG speed site, i assumed you knew about the site.
SpeedGuide.net :: Broadband · Cable · DSL · VoIP · Security · Network Tools from the menu select the TCP/IP optimzer program .
Download it. Just try the default values recommended.
2 & 3 OK.
4.
a) In FF type 192.168.1.1 ID admin password utstar.
( DO NOT change any settings , till you are confident )
Better copy the data in a notebook for future use.
b) Check ADSL status . . SNR >>>10 and ATTN 20
by SG i meant singapore site's.. well i tried the TCP/IP software..but since then my net has stopped working..i cant even connect using my bsnl connection now..as to the SNR ATTN.. im still lost
My posting
Did you change any settings in modem ? TCP/IP Optimizer has nothing to do with your connection loss..
2. see this web site to check your modem settings.
UT-300R2U ADSL MODEM MENU
or see this for full instructions. ( almost similar for UT300R2U)
http://www.appaji.net/get/dataone/bdah.html#mt800-config. TRY "PPP/PPPoE "always on mode"
http://mumbai.mtnl.net.in/triband/htm/utstarusrguide1.0.pdf
havent changed any settings.. just all's the samestill i get error 678: Remote computer did not respond
