Ubuntu Problem With Weather Applet
superprash2003
Regulars
bsnl dataone
Im not sure where the problem is but i've been having this since quite a while . I use ubuntu's weather applet a lot .. the default one which you can add to the panel. Under weather preferences under location if i choose bangalore it shows incorrect weather . it says "last update : wed,dec 24" .. its showing the same thing since almost a month. also the temperature hasnt moved.. it remains 27 .. although it shows the correct weather for every other place in india except bangalore . Anybody else facing this problem? if you do use the weather applet , please try selecting bangalore as location and post whether you get the right output.Thanks,Prash
how about you manually enter the coordinates for bangalore then try? pune was not available and i manually needed to enter coords but it appeared to work for me, this was with ubuntu 8.10 gnome. am in vista at the moment so cant check if this is due to the undersea cable cut, but you mentioned you have this problem since quite a while...
well this is on a gutsy (7.10) machine .. under LOCATION , i dont see a place where i could enter the coordinates..just allowed to choose from the given locations .well im most certain that its not because of the cable cut as i've had this problem since quite a while..
bump...anyone??Just checked on an intrepid machine.. Bangalore isnt listed now :) ..Although it still shows in the gutsy machine..but the wrong info
tried bengaluru? :D
