The other major influence on the first Test has been the umpiring. The main controversy has been around the DRS and its failings have emphasised flaws the ICC should have addressed long ago. Firstly the Jonathan Trott lbw referral highlighted the absurd decision to allow the host broadcasters to play a part in the DRS. In Trott's case the operator was utilising Hot Spot for something else when suddenly the technology was required for a referral.
The DRS should always be the sole responsibility of the cricket boards; they should pay for and operate everything that's required for the decision-making process. Adjudication has nothing to do with the
television coverage, which is there to provide entertainment for the viewers. Hopefully this latest malfunction will convince the cricket boards to take charge of the DRS, and that way every Test will then be played under the same conditions.
More important is the principle of getting the right decision, which the ICC has constantly spruiked as one of the virtues of the DRS. In many cases it has done exactly the opposite, and Broad's case was just the latest example.Instead of putting a limit on the number of referrals available, and leaving them in the hands of the players, the use of the DRS should be solely at the discretion of the umpires. The arbiters in the middle should be encouraged to make decisions and then, only if the video umpire sees a glaring error, should he intervene.
This way the umpiring standards could be raised and only the howlers, and not the 50-50 decisions, would be overturned. No system is infallible and that's part of the beauty of the game. The players make mistakes, which in turn require the umpires to come to a decision, which can occasionally result in an error. The human element is an important part of cricket's magic.
