  • Featured
  • Replies Replies 208
  • Views Views 66,809
Username: ONTUSER
I have not used this router extensively, just bought it second hand and unlocked it. Want to experiment with my MTNL FTTH.
However it has quite old firmware, and I would preferably like a new firmware with bug fixes.
The list of bug fixes and feature enhancement can be ascertained from the change log which we don't have. But the fact that new firmware was released, implies there were bug fixes.
Few users on this forum have reported WiFi drop on 5 GHz band and more battery drain on smartphone with older firmware.
The youtuber asked 1k which I politely refused.
