Using Airtel Xstream Fiber with TP-Link XZ000-G7 XPON ONU/ONT
  • Thread starter Thread starter Dravin
  • Replies Replies 9
  • Views Views 110
India
Airtel Xstream Fiber, Jio Fiber
Hi everyone,
I am planning to replace/bypass the Airtel-provided ONT/ONU and use a TP-Link XZ000-G7 1-Port Gigabit XPON Terminal ONU/ONT with my Airtel Xstream Fiber connection.
I would like to know whether anyone has successfully used this particular TP-Link ONT with Airtel Xstream Fiber.
My main questions are:
  1. Will the TP-Link XZ000-G7 work properly with Airtel Xstream Fiber?
  2. Will I get the full subscribed Internet speed without any throughput limitation?
  3. Does changing from the Airtel ONT to this TP-Link ONT cause any increase in latency/ping, packet loss, jitter, or gaming-related issues?
  4. Does Airtel allow third-party GPON/XPON ONTs, or does the new ONT need to be registered/provisioned on Airtel's OLT?
  5. If I want to use my own router, for example a TP-Link ER605, can the XZ000-G7 be configured in Bridge Mode so that the ER605 handles routing, NAT, DNS, load balancing, etc.?
  6. Is there any special Airtel configuration required for IPv4/IPv6?
  7. Are there any compatibility issues between Airtel's OLT and the XZ000-G7 XPON chipset/OMCI implementation?
My preferred setup would be:
Airtel Fiber → TP-Link XZ000-G7 in Bridge Mode → TP-Link ER605 → LAN/Wi-Fi network
My primary concern is maintaining maximum speed, minimum ping, low jitter, and stable connectivity, especially for gaming and other latency-sensitive applications.
If anyone is already running the TP-Link XZ000-G7 with Airtel Xstream Fiber, please share the configuration procedure and your experience with speed and latency.
Thanks in advance!
I had replaced my Airtel router with TP-Link XZ000-G3 ONU and it works fine, however it totally depends on your area's OLT. In my case, it's ALCL so there was no issue.
ONT is your Airtel router, OLT is the thing that's on the other end of the fiber. Nowadays, both play a role in ascertaining which third-party ONTs would work properly.
@Dravin get an sfp onu for like 4k and media converter for 1.5k. If you have a router with sfp slot then you can forgo the media converter cost
Edit: My bad, the prices have shot up
