Problem : UT300R2U Port forwarding . In Advanced. No NAT/virtual server option ?
plz tell me how to change dynamic add to static...using usb connection
is the above way( the screenshot i posted) right????????
YES. Now you have posted correctly the link. and screenshot.
You do not have a static IP. check with this web site. and go through the full page.
Very useful information at bottom of the page.
IP Info - Find your IP address
PortForwarding program usually assigns a higher IP as static say192.168.1.100.
In your programming page
See the option is and/OR
so select Use gateway IP address.
Or repeat what you see when you type ipconfig/all
usually 192.168.1.X( any number usually 2 to 10)
subnet mask 255.255.255.0
Default Gateway 192.168.1.1
Post screenshot/link for DSL status page.
PortForward.com - Free Help Setting up Your Router or Firewall
Quote
Enter your computer's default gateway: 192.168.1.1
Enter your computer's current IP Address: 192.168.1.2
First Computer's Static IP: 192.168.1.136
Click the Use the following IP Address.
Now pick one of the static ip addresses listed
above and then enter it into the IP Address box
in the Internet Protocol TCP/IP Properties page.
Put the subnet mask we previously found in the subnet mask section.
The default gateway should go into the Default gateway box.
Enter the dns servers we prevoiusly found into the two DNS Server boxes.
Click okay all the way out of this menu.
UNQUOTE
Quote
UNQUOTE
