This one in Security > WAN Access. Can't find anything related to it online. It says CPU Rate in kbps? Changing it to some other negative value errors out. Even saving the same value errors out. It says it needs an integer value.
Edit 1: Found this on the form
So it can take any value between 8 and 1048568. So why is it by default a negative integer? Have anyone tried it yet?rate_val < 8 || rate_val > 1048568
