Mine used to be in range of -30 to -35 and worked fine. I always thought its something thats is normal in a non-metro city, but once i had los due to some break/bend in patch cord ( yellow thin cable connecting onu) . Lco charged me 400Rs (200 visit + 200 cord). After cord replacement i was getting -17 which is too good ; by even slight movement it went to -24 and los ; then automatically worked. Now i never touch that wire and its -24 constant.
I believe they never fix it on wall(maybe in some location) an the thickness of patch cord is thin in case of bsnl i guess or whatever they use locally. Jio/airtel follow better installation process and the white box (fibre to patch core splice /joint) is different in case of jio/ airtel. I guess the patch cord they use have port/plugs on both side one for router/onu and other end goes into white box .
Ya, a sharp bend might cause signal issue but a better quality cord might even work with bends and minimal signal loss. An SC patch cord from a PC patch box would have been nice aesthetically. But a simple splice enclosure tray costs less I guess.
Update : My Rx is now on -23 dBm. It went down from -37 to -23 dBm by Monday night. It gradually increased everyday from about -22 dBm. And now it's magically fixed without even contacting LCO. Wonder what went wrong and where.
