What's Difference Between Ul 900plus And 900
  • Thread starter Thread starter reenu_000
  • Replies Replies 10
  • Views Views 3,182
reenu_000
Can anyone describe the difference between UL 900+ and UL 900. I hav a normal landline connection. Which one shud i opt. I can't make out the difference. In which scenario both the schemes become different. Can anyone explain me the hidden things in this....
UL 900 + --> phone rental is Nil . No Free Calls .
Each call is charged at Rs 1/- per unit .
UL 900 --> phone rental & free calls as per existing plan .
Extra calls are charged as per the plan .
If you use the phone for Broadband only & donot use it for talking
then you can take UL900+ plan .
details : http://bsnl.co.in/service/dataone_tariff.htm
In HUL 900 Plan : your telephone rent and plan will be as it is, you will have to additionally pay Rs 900 from broadband usage per monthIn HUL 900 Plus: This is a combo plan in this Your telephone rent and broadband rent will be combined Rs 900, you will get no free calls every call will be charged at Rs 1 per unit. you can use Unlimited broadband
"UL 900 + --> phone rental is Nil . No Free Calls .Each call is charged at Rs 1/- per unit . "is that means only incoming on phone (as par BSNL-Anant for cellone) & outgoing will be charged .
Incoming calls are not charged .only outgoing calls are charged .
and there are no"free" calls in Home 900+.... whereas u get free calls in Home 900 plan
Guyz.... more doubts....For BASIC BSNL plan after some 250calls one unit is billed as Rs. 1.20. So if all calls are charged Rs. 1, is UL 900+ better? Also we get reduction in rental that is for urban areas about Rs. 180. But for freecalls we save only Rs. 50 as there are only 50 calls available for urban areas. So which one is better?? :unsure:
@Reenu , it depends on your Location (Rural/Urban) &phone calls requirements . On Average howmany phonecalls you need in a month ? Do you need STD & ISD ...Just write down your phone calls requirements and analyze .
900+ will obviously be better if ur taking a new connection.........but if u already hav a bb connection.....u will hav to take 900 plan
QUOTE(avinds @ Aug 7 2006, 01:40 AM) [snapback]57842[/snapback]
[/b]
a bit of a late reply. u can close the thread, if that's possible!
..why would anyone pay 200 Rs for 50 free calls?
the way i caculate it, ul900+ is better by: Rs. 152.5 per month + .22 per call saving.
service tax=12.5%
in ul 900:
rental is180+st of 22.5 = 202.5
less free call cost = 50
(as per ul+)
so net additional is 152.5
