Yes - i have got 3 cables - out of which 1 is already supplied with the SYSTEM (which is the one you can connect this
Sony DVD Player to your
TV) so that you can enjoy movies and listen
music. (Video will be appeared on TV and Sound will be out from SONY audio system)
Following are the pictures I have taken for you:
[1] DVD Video Cable (Supplied with the SONY Audio System) - Used to take the video out from SONY and display on TV - Sound from SONY
http://img2.imageshack.us/img2/531/designwebgraphicsonyaud.jpg
Same cable as above (Zoomed out)
http://img2.imageshack.us/img2/7751/designwebgraphicsonyaudz.jpg
This one is used for AUDIO IN (Used with Computers,
Laptops, Walkmans, Discmans etc...) - Also can be used with TV to take it's sound from SONY (by attaching it into
Headphone jack into TV)
http://img2.imageshack.us/img2/3803/designwebgraphicsonyaudh.jpg
This one is specifically for TV to take out the sound from TV to SONY Audio System
- Black connector goes into SONY Audio System
- White and Red connectors go into TV
http://img2.imageshack.us/img2/9728/designwebgraphicsonyaudy.jpg
Dont worry, they guys will get you started with everything you demand. GO FOR IT
Hope my efforts helped you out. Good luck....
