Which LED TV is Best in LG/ Samsung/ Sony 32-inch section
  • Thread starter Thread starter rohitkpatil
  • Replies Replies 49
  • Views Views 91,902
Mumbai
MTNL VDSL2
Hi,
I am currently having Sony 32 inch Bravia HDTV (Not FULL HD), and it is very nice.
I want a 32" FULL HD, and i would prefer Sony only, but currently Sony not making any 32" FULL HDTV without Smart TV function (if they are,.. do suggest..but i am certain, as i called them to re-confirm)
Now here are the models i am looking into.
1) Samsung LED 32F5100 cost around 32k-34k
2) LG LED 32LN5400 (it has IPS panel) same cost as above
3) Toshiba 32PT200 around 26k to 29k
All above three models are FULL HD
I can go upto 35k, but for best panel quality. I do not want smart features.
I plan to buy Playstation 4 later, hence FULL HD is important.
Sony comes around 40k+ with smart features, which i am not gonna use, as all those features i can use with other gadgests which i already have.
All Sony TVs below that range without smart features are just HD , not FULL HD.
If anybody is having above models, please do share your experiences.
I'm also going to start browsing for a HDTV. I prefer a 40" screen. I don't need 3D or smart features. Just full HD will be fine.
I haven't researched TVs in a couple of years. At that time, there was an issue with Sony and LG. They were not able to play DTS audio because only Samsung had purchased a license. Of course, this could be circumvented by using a laptop or consoles or something like a WD live media player to play the videos. But, the USB play feature wouldn't be able to play DTS. I wonder if this has changed now with Sony and LG.
see first thing i want to know what purpose u wish for buying a new tv..for playing games, sports or watching simply tv as a general purpose thats it etc.....movie, games and sports particularly required high motion flow or rate so i strongly recommend plasmas they are simply great as well as cheaper and available in big sizes for both of u but its not that power efficient but hey! performance matters though if its satisfies ur purpose so i am giving the link to both of u....32inch as well as in 40 range ...they are great in terms of picture quality and performance....in the led range... :tasty:
http://www.samsung.com/in/consumer/tv-audio-video/television/led-tv/UA32F5500ARLXL
http://www.samsung.com/in/consumer/tv-audio-video/television/led-tv/UA40F5000ARMXL
http://www.sony.co.in/product/kdl-32w670a
http://www.sony.co.in/product/kdl-42w670a
now for plasma....its a 50incher but remember "SIZE DOES MATTER" especially watching sports and movies....so its just high on ur budget. if u consider this..but great as compare to led ....of now
http://www.panasonic.com/in/consumer/tv/plasma-tv/th-p50x60d.html
yeah i have seen that...pretty well but u can calibrate ur own way...then u cannot see any difference,,,
