Hello eveyone,
I have a broadband connection, I'm presently using a standard 4 port(LAN) modem without wifi. I have a 2 number of desktop PCs. I wish to buy a wifi modem for my new laptop. I have two choices as given below,
1. Standard single LAN port modem with wifi
2. Standard four LAN port modem with wifi
When contacted BSNL administrator, i was informed that in the four port modem,
1. The bandwidth is equally shared i.e, if my connection speed is 2mbps(256KBps) i will be getting 512kbps(64KBps) on each port.
2. Even if i connect only one port out of four, i will be getting only 512kbps instead of 2mbps. If i connect 2 ports, i will be getting 512kbps on each instead of 1mbps.
3. If i connect a laptop with a wifi, i will be getting full 2mbps and if i connect 2 laptops, i will be getting 1mbps on each(theoretically).
I was going to buy 4 port modem with wifi as i have 2 PCs and 1 laptop. But, if the above given information is true, i'm losing the bandwidth and i need to get a single port modem with wifi and connect a LAN switch for my 2 desktop PCs so that i will be getting 1mbps on each instead of 512kbps.
I would like to clarify the following,
1. Is the 4 port modem bandwidth sharing myth is true as stated above..??
2. If so, is it depend on the connection type, modem type or speed..??
3. In the above case, do i need to get a single port modem instead of the 4 port one that i preferred..??
Kindly advise me on this...
Forgot to mention 1 thing,
i'm having the plan unlimited combo 750 with 64KBps(512kbps) speed, as i'm using 4 port modem(without wifi) presently, i should get only 16KBps(64kbps) per port. But, i'm getting a speed of 61-63KBps when i connected to single port. Again the modem doesn't have wifi. Is the problem seen in modems with wifi enabled or not..??
