hiim using wireless which beam provided..im not able to connect it when i give correct password its showing connection timeout n no ip address assigned..n on da router im getting yellow color indication but if i connect da cable to my laptop its working
Try dynamic IP setting in your router / sometimes it is also called AUTO Configuration / DHCP and then logon via the beam portal........... the PPOPE option is a hit or a miss I tried with 4 routers and it worked only on 2 but the dynamic IP / AUTO IP works with every WiFi router.
i was not able to connect to da router to even go to router page..before it used to show green indication but now yellow indication on wifi and i did reset router n its fine but color indication remains da same
