Will BSNL ever provide some high speed tariff at reasonable rates ?
  • Thread starter Thread starter icycool25
  • Replies Replies 13
  • Views Views 2,548
@meetdilip,I can go upto Rs.1000 per month but the speeds must be decent with a good usage limit ! What do you suggest within Rs.1000 ?
Get two BB lines, (1) one UL750 line for 24X7 downloading = give you abt 100 GB/month, and (2) get one Home500C for night unlimited only, gives you another 100GB/month. Total 200GB/month @ Rs1250/-.
@meetdilip,
Bandwidth is costly. Though Rs. 1,000 is a big amount, we can't get both speed and data at this price. It is a choice you have to make. Either choose UL 750 and get 512 Kbps unlimited (the speed is decent. I am quite happy with it) or try Home Combo 600 which has 2.5 GB day time limit with 2 Mbps speed and night unlimited. Or simply opt for Combo 500 or Combo 600 along with your current UL 499. One will give good speed and other can be used for day time browsing. If you can extent you budget a bit, then try Home 500 and Home Combo UL 750.
@mrityu12 & @meetdilip,A big thanks to both of you for your suggestions. 2 BB lines at the same time would be a bit costly. However, the UL 750 with 512 kbps speed seems to be a good deal for me. Think will shift over to that !
