@meetdilip,
I can go upto Rs.1000 per month but the speeds must be decent with a good usage limit ! What do you suggest within Rs.1000 ?
Bandwidth is costly. Though Rs. 1,000 is a big amount, we can't get both speed and data at this price. It is a choice you have to make. Either choose UL 750 and get 512 Kbps unlimited (the speed is decent. I am quite happy with it) or try Home Combo 600 which has 2.5 GB day time limit with 2 Mbps speed and night unlimited. Or simply opt for Combo 500 or Combo 600 along with your current UL 499. One will give good speed and other can be used for day time browsing. If you can extent you budget a bit, then try Home 500 and Home Combo UL 750.
