saurav_wow
this problem is happening from the past 3-4 days...i am not getting a stable connection..i mean two say thatafter browsing for a few minutes suddenly there is no data transfer..even with downloading....everything halts(data transfer halts).....wired is that while that happens modem link is OK....dataone is still connected..am able to ping the server....117.197.240.1...but cannot ping any websites.....only solution is to disconnect and then reconnect...but after reconnection again same problem after few minutes...this is what i have noticed in the dsl settings after this problem started..BEFORE the PROBLEM:---------------------|--: AFTER the PROBLEM...........................DOWN ........Up -------|------DOWN ..............UPRate (Kbps) ...........8000+ .......500+------|------ 2044 ----------252SNR Margin (dB) .......6.1 ..........25 ------ |--------6.2 ...............7.8Attenuation (dB) .....46.3 .........16 -------|--------33............... 14Output Power (dBm)..0.0.......... 6.9 ------|-------0.0 ..............2.7Please any body help..also i am not getting the usual speed what i used to getit has reduced drastically..
