Wireless Connectivity
nalin_gautam
bsnl
I want to place modem (DNA-A-211-1) near television(for IPTV) and required to run inter-net on desktop in another room.Is there any solution or LAN card & how much it will cost. :huh:
you cannot use WIFI for IPTV.
Phone connection +adsl splitter==Modem /router---> Lan1
== IPTV set top box === TV.
Lan2 ( upto 100 meters RJ45 cable ) to computer.
Or room is not very far off WIFI
You may need a wireless LAN adapter for Desktop computer.
Laptops usually come with the unit.
Reference : similar unit ( same settings pages)
h t t p://www.chennai.bsnl.co.in/BBS/WA3002G4.htm#Wireless_security]
http://www.chennai.bsnl.co.in/BBS/WA3002G4.htm#Wireless_security
yeap airtel would be putting on a network cable from the router for the television for iptv. wireless is not not fast enough. maybe n standard is fast enough but its not popular and is very expensive :d
