rahulelectra
FIRST of alll chk ........ easy sify 1 working for ya............... dats easy as 123 ....... u enter ur user id password and it goes...........
NOW if ES 2 doent work .,,,,,,,,,,
set da folllwing details...........
a, IDENT INFO
user name
password[/b]
TRY DIS
b, EASY SIFY OPTIONS FIRST TIME CURRENT SETTING
page1: Keep alive (UNCHECK) CHECKED
Automatic Cycler (UNCHECK)
Launch Homepage (UNCHECK)
(rest settings leave dere ie 5 min , 60 min , home page add/)
page2 : ALL (UNCHECK) graph & hearbeat (CHK)
page 3: idle aut logout (UNCHECK) ( UNCHECK )
idle time out 30 mins same
idle transfer limit o.5 mb same
[ NOTE : Although I hv two ethernat cards I disabled da other 1.... and slect da one which i hv connected to sify cable... go to network places properties to disable ] dis step......hides...once we select...da nect step off FORCE MAC ADDRESS
FORCE MAC ADDRESS * ( type phiysical address of ur network card )[/b]
*( now dere is two ways I can suggest to..knwo mac address of ur NIC card..............
one is downlaod Ccget MAC address from here....... http://www.youngzsoft.net/cc-get-mac-address/download.htm
after insatlling type ip address of ur pc by claicking IP => MAC ...
to know ur MAC......similarly ya can know others AMC address too,,, if there pC is ON......
other way is to .....from within window.... GO START > RUN > CMD (command in win 98) > type ipconfig /all
and ya goes... da phisical address is MAC address .... note is doen on a txt file widout hypen (-)
SAVE SETTINGS
c, SIFY OPTIONSs
SAM I.P. 202.144.65.70
SAM PORT 8090
SAM path / [/b]
dere is another way to know ur SAM seeting....... let ,e know if dis not working
d SCHEDULER... leave as it iss ie no selction...... [/b]
hey u complete................
now go to messages.....................den connectivity.,..... LOGIN......
balh balh ya done .
IF NOT ya BAD luck ,. .......... Chk da setting.........once more........
a, IDENT INFO
user name
password[/b]
TRY DIS
SAVE SETTINGS
c, SIFY OPTIONSs
SAM PORT 8090
SAM path / [/b]
balh balh ya done .
