xtra validity for quick power 300
  • Thread starter Thread starter dupree
  • Replies Replies 4
  • Views Views 2,132
Status
Not open for further replies.
dupree
Regular
mumbai
Reliance broadband thunder 699 plan
guys im planing to go for quick power plans for my other pc and now they have changed there prices for QP plans i just want to kno whether xtra validity option is available for new QP plans coz i dont see it with the new plans i can only see that option with the old QP plans .Yesterday i called up cc and asked him and as usual cc said there is nothing like xtra validity and placed the call on hold and after few mins said that xtra validity is available for new QP plans . Can any one please confirm this ...Thanks :)
I used the extra validity option just few days earlier before the announcement of new plans from Tata Indicom. I was on Quick time 180 with balance of just over Rs. 1100. It was successfully done. I am not sure whether it will work with new plans only(150,300 hrs etc.) or the older ones also(180,360 etc).:confused:
thanks for your reply sandy84....i will think twice before going for it :ashamed:
As Per New plan .. Tataindicom really decided to make money more on Quick power plan! As It has reduced In unlimited plans 256kbps is now 750/- and 384kbps is 1100/- pmI would simply say .. If you have recharged before call that dealer and ask for previous plans if any .. like 360 or 180 plans , as i took 360 Quickpower after Hike in rates as well as reduction in hours.., This is one optionOr else u have a great offfer from that as u said that you are already user of timebased plan den do one think .. renew your plan by unlimited 384 for 3 month if u do this before september 3 ... you will get 384kbps net three months free ! this would be good for you .., Regards, -Pradeep
and how many hours can u use in that unlimited connection ?Its no use buying an unlimited connection from an isp which has very limited uptime :D. I'd 40days of downtime in 90 days + 1 month of slow browsing complaints. After this do u think unlimited connection is of any worth.
Status
