YOU TELE:- Settings to run more than one PC on LAN
  • Thread starter Thread starter sidh_15
  • Replies Replies 1
  • Views Views 2,041
sidh_15
BSNL
Hello,I am using youtele broadband.In starting they told that i would be able to connect 4 systems simultaneously using a switch.But after connecting the switch I was able to connect only two PC simultaneously.:cry:I was informed by the You Tele employee that by some proxy setting.Can anyone help me with it.....Thanx in advance........
:huh:from which site ur as per my knowledge a cust can able to connect to "YOU telecom" with one Pc and if u have to connect >1 u have to go for router switch will not allow u to connect 2 Pcs maheshtech co-ordhyd:O
