Trust me pal.........easiest way out is HARD reset....coz its a brick already, if it wont connect
I tried that and i have managed to bring back my modem to pppoe always on connection. But i dont want "Always on". Dialing to connect is ok for me.
after that u may wanna try using this link for a reference(MTNL not BSNL)
http://mumbai.mtnl.net.in/triband/htm/statip_ut.pdf
My system is configured with static ip already.
Get it working on PPPoE first(ALWAYS ON-No Dialing after the Link light stops flashing), so u never get this message:\"Connecting thru PPPOE WAN miniport\"
Coz in PPPoe u shld never get the message u described
I understood this from other members. But my curiosity is that in WAN settings my friend has some 6-7 connections, first one "PPPOE" and all others "Bridge". He dials to connect to net and it works perfect. Is router using the first setting or the best one or any logic here?
I think there are 2 or more Connections listed In WAN.....select all 2/3/4 connections.... delete all......wait 2 mins (VERY VERY VERY Important)
and then using the first link i posted to add PPPoE under WAN
I have 7 connections in exact. My router did had all the connections before when i used to dial. I deleted the connections too as suggested in ither thread and it didnt worked too.
Then LATER if u feel adventurous try this link for Bridge as in MTNL sticky, again as a reference guide with screen shots
https://broadband.forum/mtnl-triband-broadband/4251-ustarcom-bridge-mode-configuration-automatic-router-reboot/#post45374
Configured bridge mode and dialed and didnt worked. It was kept on saying the "Connecting..." message...i tried it repeatedly for one hour if you want to believe as my old connection takes 10 mins to connect.
To get the extra features on MTNL's modem I use this link
http://192.168.1.1/main.html
U could always give that a shot too.......
BSNL chaps have disabled that option too..
Let me concise my requirements here for better understanding for all,
1. I want "Dial" mode and NOT "Always On" mode
2. I have UT300R2U with stripped down firmware by BSNL(i.e no Virtual Server option in NAT. If it was there i would never want to convert to "dialer" mode)
3. I use static ip as of now. Willing to configure it to "dynamic" if it has to be done.And how about DHCP settings in LAN settings in modem page? Disabled or Enabled?
4. I "DONT" want to connect in pppoe "ALways On" and use "DMZ" option to forward ports. it's really a huge securtiy threat. I did was attacked by trojans and spywares in the few mins i used this option with a good firewall installed.
5. My ultimate aim is to get back my settings to how it was.(dialing to connect, utorrent saying port is ok and torrents getting real good speeds).
I'm thinking of taking a backup of conn settings of UT300R2U from my friend machine and install it here. Will it work out as i want the same way it is working for him? I will change the TCP/IP connection properties also from his machine.
I also have a new suspicion now. Do ESET Smart security block connections to outside itself in initial default mode(i.e not allowing to connect to net using dialing at all in first case)? In that case i can try uninstalling it.
Great thanks for all the folks who are trying to resolve my problem.
I really believe you guys are the best out here in web about dataone and can help me.
