Hello ,
This is to inform you a concern I am facing by using the ACT Broadband. This needs to be forwarded to the Network Engineers who can understand the issue better.
I was completely satisfied with your service, hardly any disconnection nowadays, till last month. I have a CCTV system installed in my house since a year and it is connected to the broadband via my wifi router where ports are forwarded, so that I can monitor the house when I am away. I do not have a static IP, but that is not a problem, I have a computer running at my home which will update the dynamic IP address of the router and map it to a domain where I can access the CCTV.
Since last month, the IP which the computer at home updates is not the correct ip address which I can access from anywhere. It looks like my connection is behind a NAT or a different router and not accessible from Internet. I cannot 'tracert' to the IP address of my home network. When I searched the broadband forum, I came across a post by a person facing similar problem with port forwarding.
Here is the link to it: Problems with Port Forwarding due to NATing | India Broadband Forum
Can you please let me know what ACT have changed in the network and is there a way to bypass it? Static IP is a solution but I know you will charge more for that, which I do not prefer. I am just asking you to be like other broadband providers. I have a backup BSNL connection at home, when I connect the CCTV system to that, it is updating IP correctly and all is fine. So something has to do with ACT Broadband network or my Router. I have checked all the settings in my router, It is fine and it has not been changed since a year.
Any help would be appreciated.
ACT Account ID: 170700
