ADSL link down every few min. using WA3002-G1. WTH is wrong?
The picture is all good.
Only that I don't use the BSNL phone,
so its not connected with the splitter.
Rest of the cords are as shown in the picture.
1.
Not advisable.
2.
You have to use the ADSL splitter and
connect a Phone to the Phone PORT
to complete the circuit
(either Phone on cradle or off cradle )
3.
Even with the ADSL splitter in circuit,
the modem RJ11is connected
DIRECTLY to main Phone Junction.
4. Try this and give feedback .
1.
Not advisable.
2.
3.
I mean the PHONE is not connected. I use the splitter as shown in the picture above.
I talked with a bsnl man. He told me, must be cause of weather the splitter is gone bad, and he advice me to put the phone line directly to the modem and then use it.
This is the error log of the modem:
2/12/2000 1:16:16> bridge only stop
2/12/2000 1:16:16> SNMP TRAP 3: link up
2/12/2000 1:16:16> Quick bridge not allow multi-channel
2/12/2000 1:16:17> netMakeChannDial: err=-3000 rn_p=8048d690
2/12/2000 1:18:57> Last errorlog repeat 78 Times
2/12/2000 1:18:57> MPOA Link Down
2/12/2000 1:18:57> SNMP TRAP 2: link down
2/12/2000 1:19:8> netMakeChannDial: err=-3001 rn_p=8048d690
2/12/2000 1:19:27> Last errorlog repeat 13 Times
2/12/2000 1:19:27> MPOA Link Up
2/12/2000 1:19:27> Quick bridge not allow multi-channel
2/12/2000 1:19:27> bridge only stop
2/12/2000 1:19:27> SNMP TRAP 3: link up
2/12/2000 1:19:35> netMakeChannDial: err=-3000 rn_p=8048d690
2/12/2000 1:20:44> Last errorlog repeat 66 Times
2/12/2000 1:20:45> netMakeChannDial: err=-3000 rn_p=8048d690
What is means : Quick bridge not allow multi-channel
How to fix this?
PC is online 48 min. now and I am disconnected 3 times.
Last night I change the Modulation to DGMT and it was disconnecting me again and again. I change it back to ADSL2 PLUS. And I also remove those DNS IP addresses from modem and PC. Now atleast I stay connected more than 3-5 minutes. When I did the above changes, it disconnects me every 30-40 seconds.
Any suggestions please?
http://xs841.xs.to/xs841/09313/wa3002g1_deviceinfo898.jpg
Post screen shot for your modem.
Upload in TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
2. In Advanced options look for SNMP .
If enabled disable it.
3
Recheck your settings for LAN connection.
http://www.maharashtra.bsnl.co.in/ssa/nashik/wa3002.htm
4. Recheck the lease time in this page. default is 0
http://img200.imageshack.us/img200/8416/laninterface.jpg
5. Start RUN type cmd OK
new window
type ipconfig /all
Post full data including lease time now.
3
WA3002
Status
SNMP
SNMP says public.. there is no enable/disable option.
And yes, the net still gets disconnect often. :icry:
3
WA3002
http://img200.imageshack.us/img200/8...ninterface.jpg
new window
type ipconfig /all
I saw your earlier post and added the pics. Added rest of info now.
3. ALL DONE. Now auto connecting - no need to dial.
Could not set wireless security as WEP-64 Bits - Says key is wrong.
So I set it for WPA2-PSK with a password and it saved it. And I restarted modem 2 times.
4. Lease time is exactly same as this picture.
5. IPCONFIG IMAGE:
http://img195.imageshack.us/i/ipconfigall.jpg/
tinypic not opening now, so I use imageshack.
You are back to Square 1.
No suggested changes made to your
modem/router settings.
Please await other users suggestions
SUMMARY: Posts 1 to 15.
adsl splitter Ok.
D/L U/L
reported:
Connection " Always On now "
Modulation ADSL2PLUS
Annex Mode_A
SNR Margin 42.1 23.5
Line attn 25.0 17.3
Data rate 2048 509
ipconfig /all
http://img195.imageshack.us/img195/483/ipconfigall.jpg
DNS 192.168.1.1 only one used .
Mate am havin the same problem so i know exactly how ur feeling... its frustrating i know... Just hoping ders a permanent solution to such a strange yet very common problem.. cheers...
I was with the same problem... "snmp trap", etc, and the connection loose (everytime!)then, i changed in the advanced configurations the modulation from "auto/adsl2+" to "adsl2" (G.DMT worked too, but adsl2 become more fast in my case)... Other people changed this too and solved the same problem..hope it helpsBye!
So anyone found SNMP TRAP 2: link down solution?
See under management. Not needed.
( with some firmware version may be seen disable. )
Also dis able Client_tr069 if enabled.
Un check in DSL page adsl2 + mod mode.
( expect GDMT or ADSL2 to be connected )
Check Under Statistics/ADSL data for snr attn line speed Rate.
copy /paste details here.
If more than one system is to be used , change over to
Always On" PPP?PPPoE mode in wan Page. Uncheck "bridged " etc.
Check my Sticky post WA3002-g4 quick reference for settings.
( Chennai BSNL link )
