ADSL USB Driver Help
  • Thread starter Thread starter plabon
  • Replies Replies 5
  • Views Views 2,461
Broadband
Any one here using adsl usb driver? Please Help. I am using Huawei modem. The usb driver which I am using in my windows 7 is not supporting in windows 8 or 10. Do you have any soultion? Or Do you have any latest adsl usb driver. Any kind of suggestion would be great help. Thanks.
**My model is HUAWEI SmartAX MT882a.
It shows something like "td X 0000000000000000" . It shows before installation. I mean It does not install.
Yes. I can install in my windows 7 but it does not install in windows 8 or 10. It stops by showing that massage. Is the problem is with the exe file or for the old software?
Tried running that on compatibility mode? If the folder where the exe file resides have some .inf files, you can try installing the drivers via the Device Manager route.
