Average per month usage 200 GB. High usage monitored for 3 months.
yeah but downloading more than anticipated usage THRICE or FOUR times in an year Wouldn't bother them then!
i would stay with a service provider who is honest about the realities of running a profitable
business.
the guy is not enforcing a FUP on your plan. he just wants you to be reasonable with excessive usage.
Well, thats Good thinking.. running a biz with Transparency about plans and their ideas is good.
You are getting the same confusion as sach92.
The other ISP will also do what Hayai will do for high usage, but they will not make it public that they will do so. Hayai are making it public that's all.
Mgc has said this before as well, true unlimited is a farce and nobody can do true unlimited. Some tell us this, others don't.
No, I am not confused Its crystal clear for me and dont compare wid that kid?? :huh:
I was comparing them with the tariff of fivenet tariff and speeds from 5net See the above posts and if you can see tat.. Its ok ???
and that is the reason why airtel annoys me so much. they want me to pay 1200 rupees for 15GB at 1mbps and 256kbps after that. that is NOT REASONABLE.
Thats sad actually.. 1200 mein u should get more than that!!
Well, It has also been said by MG if there are 100 users using say 50 GB, & one user uses 1 TB - he would not still be too concerned.
He is more concerned with the average (here the average would be 1.5 TB for 100 users, his buffer is 20 TB)
Yeap! that wouldn't mind him at all..
umm?
arey bhai aap ka internet kaam nahi karega.. you will be able to access only to hayai zone! after your billing limit is over!!
