Annoying problem while trying to open a website
  • Thread starter Thread starter Kevin
  • Replies Replies 43
  • Views Views 7,226
there are two models. One UT00R2U is identical to Beetel 220BX. page i have givenif different older model same way look for dsl settings.
GDMT and Bitwsap is already enabled in my modem,,,,, is there some other way .... Thanks..
try changing MTU values to 1492,1454 etc..whichever works for you..
can u explain how to change MTU values, plz
::TamilVibration:: - Home ( another proxy idea tinyurl )
Again tried now Opening Ok. direct as well as via trinyurl.
Para two:
1.In you modem see in the menu access control
check all are enabled in /LANWAN ( telnet/http/ftp etc)
After opening the modem type ( see page opens or not )
192.168.1.1/scsrvcntr.cmd?action=view
( equivalent from Beetel 110Bx1)
2. Have you updated your OS ? What is the firewall program you use ?
::TamilVibration:: - Home ( another proxy idea )
i will try it and report to u , thanks..
@essbebe, i enabled telnet, http , ftp both in LAN and WAN , but still the website is not loading fully ..it loads half webpage and again automatically it starts loading from the first.. another problem, i am getting 555ms ping when testing my broadband speed at speedtest.net , how to reduce these pings.???
Para two:
I have turned off windows update , firewall....
see my FF page with adblock plus and flash block.
Probably your PC memory is not enough.
If you want to download songs, why you want to wait for the full page again and again with all flash and jpg/png pictures /? /
