kindofblue
Kind Of Blue
Create your own list type field called Composers, the std one with mp3 (assuming you use it) won't work unless u enter it as "composer a & composer B". With a list ype field you would say composer A;Composer B; Composer n..etc when you create a viewscheme you will see the same track listed under any of the 3.
Umm, i mean a heck of a lot more than the std. rating field
, see above for just "a"
Much the same in amarok, without using tags - List all composers in the Artisit fileld; all fields are searchable, use your keywords...
Possible via plugins to do lyrics.
But not out of the box?
It seems to have a COM based scripting interface... Thats great while wrting power apps but quite an overkill while you're cobbling together a small one... Not something that would get me writing my own plugins.
Bear in mind tho that all of these solutions depend on the info being correct in the first place so often they are either inaccurate or incomplete or non-existant so in the end the only way to do it properly is manually.
The other things you mention are child's play renaming tags from filenames as well as vice-versa etc. Tagging is one thing thats very quick & intuitive. I don't save tags back to files at all but only in the library. Since i use checksum files to check media for integrity.
Can your player do that ?...save only in the library.
No, I don't think Amarok does that; and wisely so. I would like all info I saved on to the tag fields to stay with the tracks(including embedding album art) so that when i transfer the files across to a portable or give them to a friend, they are not lost.
I would drop it within a heartbeat if i could get just those basics done properly & quickly in a free player but for several years now not a single one is even past half way there in terms of flexbility & speed.
You havent used Amarok have you?
Again, comparing a paid solution to a free and open source one is not something I would do but Amarok does satisfy all my expectation from a music player. Depends on how you want to use it maybe?
