ok, im not sure about the new UT300R2U..but the one i am using has something called NAT-DMZ.. open your browser type 192.168.1.1 ...type admin as username and password... you should find an option called advanced setup.. click there, then you should find,NAT,click again then you should find DMZ.. there you should type your computer's ip addresss.. if you dont see these options.. then just open your browser type 192.168.1.1.. type admin as username and password and post a screenshot here
i have typed 192.168.1.1 in to the browser but its not opening. why? what should i do. i am attaching my browser screen shot.
don't confuse about that red rectangle it will come after installing service pack 3. it comes when page don't open.
now please help
why my screen shot is not coming. never mind. the thing is browser is not opening router settings. what should i do my modem is UTSTAR 300R2U ADSL 2+.
please help
from what i can see , it looks as though you are dialing from your computer.. that means you are using bridged mode.. for that you dont need to open any ports on your modem/router... are you getting slow speeds in utorrent?? disable your software firewall for 1 min and check if the speed improves.. if so then you need to configure your software firewall..
yes,even i thought so.. but then it wouldnt be possible for him to get that PPP Adapter to connect and give him the 117.x.x.x ip...might have not pasted the whole output!!maybe having another LAN card
Thank you very much i disabled my firewall and the first time i got green status in bittorrent. in night unlimitted period i will check how much speed i get.thanks to all of you my friends.:thumbsup::thumb:
