Best Wireless Routers for Home Use?
IMO you should go for DIR-615, should cost you around 1900Rs. 300Mbps, 802.11n, 4 LAN Ports 1 WAN Port. Dual Detachable Antennas, Decent Range. You can always add cheap ADSL modem to it's WAN Port and share your bsnl or airtel or other ADSL connection through the WiFi and 4 LAN ports..NOTE: Keep the WAN Port Speed of DIR-615 to 10Mbps Full Duplex if you are going to use it with cheap ADSL Modems.
Dear All,
I am planning to buy wifi router for home use, Can you please recommend me best possible router..But it should meet following requirement...
1) Should have range to cover 3bhk or 1000 sqfeet
2)what is modem & without modem router...i have broadband connection which directly connect to the port which than require username password, so what type router shd i buy?
3)150mbps or 300mbps
4) please give me some suggestion and ideal price to buy...
u want adsl or basic router ?
manu1991 said:
That's interesting. I never knew this. So you can use an ADSL Modem+Router device for a Cable internet connection as well? but where would you insert the internet cable since there is no WAN port?
androidfreak said:
I have seen an option in some adsl wireless routers where we can convert the LAN1 port to a WAN port using the configuration page.
I tested Dlink 2750U with my Tikona connection with the above said method.
BRO..I REQUIRED WIFI ROUTER SO THAT I CAN CONNECT MULTIPLE DEVICE AT THE SAME TIME.I m using local broadband n(Honesty net solution)....they provide single wire which directly plugged to the port behind..i m not that smart in computer terms..so dont know about adsl or basic router. my only query was wether i purchase wireless wifi router with modem or without modem.
The one without modem. The one without ADSL will have one WAN port (RJ-45) and that's where your local ISP-s RJ-45 connector will go in. To name a good affordable home WiFi routers, I have installed and tested the D-Link's DIR-615 (Rs.2,000 approx) in many offices and houses and it does work well for them. But I would recommend Netgear if it's available to you :) . I'm an Hardware and Networking Professional BTW.
Dont go for TP -Link because they have a very thin support base in India, if at all you require a replacement you need to run around. I got a DSL modem as well as TP Link 1043 ND router they work alright but i sent some queries( 3 times) to support id still no reply from them.
Strange, because I was having a problem with rebooting via telnet and I opened a support ticket on their website at 9 PM and they replied to me at 10 AM the next day with screenshots and detailed instructions on what to do? Did you email at support.in[at]TP-Link.com ?
