@ghpk, I guess you are misguiding OP
, Did you see the MDMA snapshot he posted? Come on man, In which world 3G tower having capacity of 128 kpbs(even EDGE enabled tower should be having minimum capacity 236 -456 kpbs)? Where ever he goes and uses this same SIM, I'm sure he will be limited to 128 kpbs and this speed profile was set in HLR. I already told you in some other thread, that speed limit is not only related to tower capacity. The modem also does matter and important factor is speed profile set by the operator. For eg, if you see DOCOMO 3G tariffs, they have speed ranging from 21 mpbs to 128 kpbs. This doesnt mean, for 21 mpbs they will use different tower and for 128 kpbs they will use some other tower. Please get the fact!
---------- Post added at 07:03 AM ---------- Previous post was at 06:57 AM ----------
Some time modem speed limit also matters, but OP case modem speed not an issue, since no where i've seen 128 kbps modem. For eg, i'm using K3765 as well as UMG1831, when i use K3765 , download QoS is 8XXX and for the same SIM if i use 1831, download Qos will show 14200!
one month back i recharged Rs 95 6b plan from docomo at that moment my mdma software showed downlonk speed of 21mbps and it gave some good speed of above 5 mbps, suddenly after few days speed was very low and mdma was showing 128 kbps and i was getting the same, than i recharted Rs 9, 10mb pack and speed again rose to 21mbps. The same thing happened to my bsnl 2g sim, now 2g sim show downlink of 240kbps whereas a 3g sim og bsnl shows 16mbps, i am using both.
