IAM TELLING U THE REAL PROBLEM THAT COMES WITH BSNL 3G PROBLEM,,
FIRST OF ALL 3G SIM AND 3G NETWORK(HSDPA) ARE TWO DIFFERENT THINGS......BSNL WHICH CLAIMS SPEED OF 3.6mbps IS FOR 3G SIM WHICH HAS MUCH MORE DATA TRANSEF RATE FACILITY THAN THE USUALL 2G SIM,,,,,NOW MAXIMUM PEOPLE INCLUDING ME ALSO BYE 3G MMX MODEM AND PUT A 2G SIM IN IT ND START SURFING,......WHILE USING 3G NETWORK WE THINK THAT IT WILL PROVIDE 3.6MBPS SPEED,,,,3G NETWORK CAN PROVIDE THAT SPEED BUT REMEMBERU R JUST USING 2G SIM WHICH DOES NOT HAVE THAT HIGH SPEED FACILITY,IT CAN ONLY PROVIDE 256kbps TO 750kbps (approx) ..............so dont get panic if u dont get that mush high speed,,,also 3G NETWORK WITH 3G SIM IS OFFERED BY BSNL WITH A MONTLY RENTEL OF Rs3000 .................SO FORGET ABOUT THAT
NOW TO GET MAXIMUM SPEED GO IN OPTION MENU OF MMX NETWORK> THEN CHANGE MANUALLY IT TO 3G THEN U WILL GET SPEED MATCHING WITH YOUR FRIEND EVEN MUCH MORE THAN HIM......BY DEFAULT IT IS SET TO THOSE NETWORK WHICH HAVE HIGH STRENGTH INWHICH 2G LEADS OVER 3G BUT FOR DATA TRANSFER 3G IS BETTER,...SO CHANGE UR NETWORK MANUAALY ND NJOY.............ALSO SMTIMES 3G NETWORK IN NOT AVAILABLE AT THAT TIME CHANGE IT AGAIN TO 2G ND SURF...AFTER SMETIME TRY AGAIN WITH 3G NETWORK USUALLY IT GET AGAIN AWAILABLE AFTER 1/2 AN HOUR..........DONT FORGET TO THANK ME
