BSNL 3G: Suggest Me... Huawei K4505 (or) Huawei UMG1831?
  • Thread starter Thread starter vmsanandh
  • Replies Replies 193
  • Views Views 68,472
where to enter extra initialisation command?
I am using UMG 1831. It is not connecting with airtel sim. when i called cust. care. they told me to enter extra initialisation command and they gave me the code. But i dont know where do i have to enter this code. pls help....
You have to give the extra initialisation command to modem i.e.
riight click on my computer ---> manage --> Device manager --> modems category --> right click over your modem i.e.umg 1831 --> go to advanced tab
in the advanced tab you can give extra initialisation command
I think you have not created connection properly. Check whether you have created connection properly after giving initialization command. have you entered
thanks a lot livelively.......for your valuable reply..
Dear All, Can anyone let me know,where in MUMBAI , can I get Huawei 1831 3G 21.6MBPS USB modem Stick?????? Thanks and Regards
Can any one inform if Huawei UMG1831 and E1831 are same or different.If they are different what is the difference?
