BSNL Broad Band keeps disconnecting and connecting
@/members/basekickedin/
Open 192.168.1.1/home.html
see this page. Make a screen shot of existing entries.
NOW enable bitswap both.
May be Power/ Mod setting also available. here.
I don't have this modem.
I have a BSNL broadband unlimited 900 connection.I got Nokia Siemens C2110 modem from BSNL. The internet connection goes off approx every 10-15 minutes.Please find below the data of Modem: DSL Status true Last Failed 0x00000000 Downstream Data Rate 8190500 Upstream Data Rate 508900 SNR (Downstream) 24.5 dB SNR (Upstream) 28.0 dB Line Attentuation(Downstream) 25.0 dB Line Attentuation(Upstream) 13.0 dB Connected Standard BisPlus=========================System Information Model Number Vulcan BSP v0.01 / Vulcan CSP v0.01 Firmware Version V55.1.04.01 DSL Firmware Version E.37.9.32 Besides, there is no port forwarding. Is there any updated firmware which can correct these problems?Thanks.
http://img138.imageshack.us/img138/4396/nokiasiemensc21102mq7.jpg
http://img84.imageshack.us/img84/3528/nokiasiemensc21100pv8.jpg
Open in IE 192.168.1.1 ID admin password admin
Then enter 192.168.1.1/advan_menu.html
Then secur_menu.
Standard BisPlus : If you find GDMT change .
Check lease time here;
start run type cmd type ipconfig/all
recheck in WAN page.
REF:
C2110 ADSL MODEM (Type-A) MENU
Hi,Thanks for the reply.Port forwarding issue is resolved, however, frequent hanging of connection still persist.I dont know what is wrong with the connection. I had a talk with BSNL people also but they were unable to help me.When the connection works fine, it works fine for 10-15 minutes but then after 15 minutes or so the connection hangs again and some sites open and some does not. Downloads and torrents are working fine.I tried other dns servers as well but in vain.Tried gdmt also. But i do not see any change. What should i do now?Please help.
Hi, I also get this problem of disconnection. It's not fix when it disconnects, I checked line from the splitter, it is ok the values of SNR are as below - SNR Margin (dB): Downstream - 34.5, Upstream - 17.5Attenuation (dB) Downstream - 17.5, Upstream - 7.7 Could you please suggest if these values are ok?If not, what else could be wrong with the connection?I have PC with Pentium 4, 2 GB Ram so no PC problem for sure.Kindly suggest..Thanks in advanceAmit
Hi, My ADSL router is ITI make - model no - DNA A211-I. I tried to search where I can change the ADSL2+ to bitswap but could not get how to change it. From Device Info -> statistics I got below infoMode: ADSL2+ Line Coding: Trellis On Status: No Defect Link Power State: L0 Downstream Upstream SNR Margin (dB): 34.5 17.3 Attenuation (dB): 17.5 7.7 Output Power (dBm): 12.3 -1.8 Could you please suggest how to change the mode to bitswap?Thanks in advance, Amit
click DSL settings in the left hand side menu.
See screenshot given earlier.
Read suggestions carefully.
You have to UNCHECK other Mod ( modulation ) settings
keeping enabled
GDMT T413 Glite and Bit swap enabled.
Annex M disabled.
Save Reboot go to
Maintenence
click SAVE reboot.
Wait for two minutes.
Recheck SNR etc.
