to set a static ip go to control panel->network connections then right click on Local Area Connection properties.. and go to tcp/ip properties.. there you can enter your ip address manually.. regarding port forwarding , look for something called as virtual server, this page will help in port forwarding..if that is not visible then look for NAT-DMZ
