For configuring the
D-Link GLB 502T modem use the following :
in the Internet Explorer address bar type :
http://192.168.1.1/
then when it opens then type : username : admin
password : admin
Press Enter
Now click on new connection,
now in the blank space against New_Name : type DATAONE orwhatever you want to
against Type Select Bridge
Encapsulation select LLC (it is automatically selected by default
Select LAN : Langroup1
Now leave everything except VCI as it is and select VCI as 35
now press apply
now go to TOOLS
select system commands
select Save All, press or enter and logout. thats all, now you are ready to surf under lan card in BSNL Broadband. no more confusion or extra workouts please.
Once you are thru with this, then you can do any R&D on other settings and revert back to above settings when you are done with.
I hope this should work for all practial purposes. I am doing the same thing for many people here everyday. As the settings are commong for bsnl all over india, this should sure work everywhere.
please do not confuse yourself with tampering the unit or consulting the service station.
