BSNL Broadband: Dlink Glb-502t Help Page
  • Thread starter Thread starter harman163
  • Replies Replies 133
  • Views Views 67,493
Hey guys, the steps explained above, with Bridge are the only true settings possible, Also u need to create a dial-up, secondly using it with a USB makes no difference coz the max, data transfer is at 256Kbps, also i wuld not recommend this modem without a UPS or where there is no voltage fluctuations protection, i have seen many dlinks getting faulty,many show ADSL led on but still no data transfer, even more many show all led but niothing happens, avoid D-Link if there is no protection, use Netgear instead it uses PPPoE settings, no need for qany firmware upgrade reqd in dlink at present, Also pls ensure that there are no parallel connections for the phone, else u will face problems
I am not able to apply the patch. When I click on the batch file it does exeutes but when see the device information on the router properties the mac address doesn't seem to be changed. Anyone got any idea?
QUOTE(daddykazaa @ Oct 5 2006, 02:40 PM) [snapback]64199[/snapback]
I am not able to apply the patch. When I click on the batch file it does exeutes but when see the device information on the router properties the mac address doesn't seem to be changed. Anyone got any idea? [/b]
Have u entered the mac address correctly and replaced the 8th digit of mac address 0 with 1.
Hi daddykazaa! I hope you are properly entering DSL MAC id and not those other ids' displayed on the information page. The page looks like...
Model Number GLB-502T
HW Revision P1R4
USB PID 0x6060
USB VID 0x0451
Ethernet MAC 00:17:7C:00:1E:86
DSL MAC 00:00:10:00:23:BD
USB MAC 00:E0:A6:66:41:EC
USB Host MAC 00:E0:A6:66:41:E1
^ Out of all the above you should note down the DSL MAC, change the 8th digit from 0 to 1 in the txt file. Remember to save and close the txt file before running the batch operation.
HTH!
Dear Mastermind please read the instructions posted by harman163. Here is what he wrote:This is a fix for D-Link GLB-502T PPPoE mode.Please follow the following steps to update the settings of GLB-502T.Copy the folder to c:(root drive)1. Note the mac id of your router which comprises of 12 digits (combination of numbers and alphabets)Pasted separately on the bottom of your device.eg. mac if of your device is "00:17:7C:00:1D:4F"2. Open mac.txt file and make changes as followsSEND "echo HWA_3 00:17:7C:01:1D:4F > env\m"3. Replace the 8th digit of the mac id 0 with 14. Save changes to the file mac.txt file5. Run mac.bat file6. Reboot your router. Updation is complete.And here is what I've got after applying the patch:Product Information Model Number GLB-502T HW Revision P1R4 Serial Number 756756675 USB PID 0x6060 USB VID 0x0451 Ethernet MAC 00:17:7C:00:0C:F6 DSL MAC N/A USB MAC 00:E0:A6:66:41:EC USB Host MAC 00:E0:A6:66:41:E1 Software Versions Gateway 3.7.0 D-Link GUI 3.7.0A.1 ATM Driver 5.00.07.01 DSL HAL 5.00.05.00 DSL Datapump 6.01.01.00 Annex A SAR HAL 01.07.2b PDSP Firmware 0.52 Boot Loader 1.2.1.5 He has clearly written to see your mac from the bottom of the device and thats what I have done. But I don't understand why the Ethernet MAC not changing after applying the patch, and the DSL MAC shows N/A.Do you think the patch has already been applied?
^ @daddykazaa , As I understand it , the patch has been applied .
QUOTE(seshu @ Oct 5 2006, 07:45 PM) [snapback]64231[/snapback]
[/b]
Follow, the steps mentioned by harman, my D-Link seems to work fine after that. Till now have not faced any issues. Anyways, just a little off the topic, do people here have good suggestions for all the other brand modems for using it with BSNL and how is the bridge mode different from PPPoE, any specific disadvantages etc?
Guys, I bought a D-Link GLB-502T modem a few days back and I am unable to get it to connect using PPPoE.
I read what has been posted in this forum about the patch to be applied. However I am unable to download the patch from link-removed because the security code that has to be entered before downloading the file is not showing up in my browser. I am using IE 7.
Then I started searching for an alternative file called TST10.zip. I found one and downloaded if from ftp://ftp.elf.stuba.sk/pub/pc/comm/tst10.zip.
This file is a telnet scripting tool Version 1.0. Then proceed to make a txt file called mac.txt containing the following command:
SEND "echo HWA_3 00:17:7C:01:4B:46 > env\m"
After that I executed the following command from the command prompt:
C:\Documents and Settings\Administrator>tst10 /r:c:\mac.txt
Now when I run this command a Telnet Scripting Tool v.1.0 window is opening listing the usage and syntax and parameters of the tool. When I try to close the window I am getting an "Abnormal Program Termination" error message.
Then I logged into the modem settings (through Internet Explorer, IP Address:http://192.168.1.1, user:admin, password: admin). Then I went to Tools\System Commands
and clicked on Save All and then on Restart.
Then I went to the Status/Product Information section. This is what I found there:
Product Information
HW Revision P1R4
USB PID 0x6060
USB VID 0x0451
Ethernet MAC 00:17:7C:00:4B:46
DSL MAC 00:00:10:00:25:8E
Software Versions
Gateway 3.7.0B
Software Version 3.7.0B.0
DSL HAL 5.00.05.00
DSL Datapump 6.01.04.00 Annex A
SAR HAL 01.07.2b
PDSP Firmware 0.52
Boot Loader 1.2.1.5
I can see that the 8th zero under (Ethernet MAC 00:17:7C:00:4B:46 ) is still a zero and has not been changed to a 1. Could someone plz tell me what is the problem?
Have I overlooked something? Is the TST10.zip that I have used not the one used to apply this patch? Could someone plz send me the original TST10.zip being used here
as I am unable to download it from from link-removed? I would really appreciate it if someone could send it to rational610@yahoo.com.
daddykazaa: If you have understood everything and downloaded the correct TST10.zip file from link-removed and applied the patch, then why is the zero in your Ethernet MAC address not changing to 1? Could u update us?
Anthony N Nishat: It seems you have successfully applied the patch. Could you tell me where I have gone wrong?
rational
QUOTE(rational @ Oct 5 2006, 11:44 PM) [snapback]64266[/snapback]
SEND \"echo HWA_3 00:17:7C:01:4B:46 > env\m\"
Now when I run this command a Telnet Scripting Tool v.1.0 window is opening listing the usage and syntax and parameters of the tool. When I try to close the window I am getting an \"Abnormal Program Termination\" error message.
Product Information
HW Revision P1R4
USB PID 0x6060
USB VID 0x0451
Software Versions
Gateway 3.7.0B
DSL HAL 5.00.05.00
SAR HAL 01.07.2b
PDSP Firmware 0.52
Boot Loader 1.2.1.5
rational
[/b]
Hey Rational,
First you have to create Mac.txt with following data and not just the one line you mentioned
192.168.1.1 23
WAIT "BusyBox on localhost login:"
SEND "root\m"
WAIT "Password"
SEND "admin\m"
WAIT "#"
SEND "cd /proc/ticfg\m"
WAIT "#"
SEND "echo HWA_3 00:17:7C:01:4C:D2 > env\m"
WAIT "#"
SEND "echo macc > env\m"
WAIT "#"
SEND "exit\m"
wait "#"
This assuming you havent updated the password for the root/admin user. See the echo HWA_ line, in that mention your ethernet mac 00:17:7C:00:4B:46 and change it to 00:17:7C:01:4B:46
Save the file and run the command again. And note that DSL mac is what changes it becomes NA.
Hope this info helps.
