BSNL Broadband: Neighbour's Network Visible, Mine Not
  • Thread starter Thread starter arihantddn
  • Replies Replies 22
  • Views Views 5,799
I have exactly the same problem as arihantddn is facing and i am unable to find any plausible solution for it.
Both of you facing one common issue termed as wifi channel conflicts.
If your neighbor's wifi router uses recent wireless radio transmission technology such Wifi N etc and yours is not that recent then your neighbor's wifi signal would be more powerful than yours.
And if both your neighbor router and your router uses same wifi channel, then your laptop can see only your neighbor's router and not yours.
So, check if your router supports automatic wifi channel switching, if not, then you have to find out unused channel number using inSSIDer
What i feel it is a wifi card problem .The router might be in G or N spectrum and the wifi card is old .. So it wont detect..Change the channel in the router to 1 or 2 where u can easily get and change once it is sorted out.It is in the router settings.
But i can detect mine as well as my neighbour's wifi simultaneously 2 out of 5 times. Its only those 3 out of 5 times when i cannot detect my wifi and many of those times the neighbour's wifi is turned off.
i didnt get clearly what u tried to explain. can u please elaborate it? My router is in g spectrum and the number of channels was by default 11. What do u want me to change after changing my channel to 1 or 2?
yes exactly.. then u can rule out the interferane and card issues.. In the router change it to channel 1 or 2 ... All cards will support it..
change the channel and see...
I changed the channel to 1 but it didnt help me. Again when i turned on my modem for the first time it was undetectable but after switching it off and on again I could detect the wifi. Anyone else has any fix for this problem?
Since when you face the issue both your phone and laptop cant see the ssid that means the laptop is fine. If there is some issue it is with the router. Sometimes it display the ssid and sometimes it doesnt. Now what the problem is needs to be diagnosed. I guess it wont be a bad try to factory reset your modem and if possible upgrade with the latest firmware. which modem do you have?
