BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
Hi there . I need (serious) help too .I have accidentally upgraded the firmware of my MT882 with a MT880 one.Now , i am reported to own a MT880 router. I need detailed help in reverting back .I have tried these options .1) Done a Hard reset by poking a pin at the back , in this manner ,all the settings are reverted but not the firmware . 2) Tried Upgrading to the default firmware ( as suggested in this forum ) , but it doesnot work . It sys invalid file , and when i rename the .bin files to . xDSL , it says Invalid Upgrade File!!.3) I have also tried to upgrade it via TFTP server , but i fear of screwing things more. It says something about Unlock ( sorry i forgot the exact error msg ) .I am very frustrated and i need immediate help from u guys . I know that only u guys can help me . so please help me .Now my USB LED is blinking on Data Transfers , but i have connected it to my Ethernet Port. Please help me . ASAP
QUOTE(scattyraj @ Feb 3 2007, 10:36 AM) [snapback]78358[/snapback]
don't worry ....
i was facing this prob a time ago...... hey this is the prob with settings of browser only...
do .....
1=
uninstall IE7 ...because it has high security features...causing prob..
2=
after that...u have to get u sytem properly cleaned...
so u have to change ur browser...because IE is pretty weired...to use
I recommend
Code:
http://www.maxthon.com/redir.htm?url=http://dl.downloadhosting.com/download/myie2/mcombo.exe
don't use its beta versions,
then go to
options ---> clean system ----> clean all
hey will also make ur net faster ... n keep ur system clean
then open..... portal websites.... this has worked with me... n hope to work with u too...!!!
enjoy!!!!
[/b]
THANKS FOR YOUR HELP. I AM USING FIREFOX AS MY DEFAULT BROWSER AND WAS USING IE5 ONLY TO SEE MY BROADBAND USAGE AND IT WAS WORKING FINE. SOME OF MY FRIENDS HAVE COMPLAINED ABOUT THE SAME PROBLEM BEING DISCUSSED HERE. I USE TO CHECK THEIR USAGE IN MY BROWSER (IE5). BUT RECENTLY I UPGRADED MY IE5 TO IE7 AND FACED EXACTLY THE SAME PROBLEM. I WAS NOT ABLE TO CHECK USAGE THOUGH I WAS ABLE TO LOG IN.
THANKS TO YOUR BROWSER(MAXTHON) NOW I AM ABLE TO CHECK THE USAGE. I WAS HESITANT TO ROLL BACK THE IE7 TO IE5 SINCE SOME WEBSITES INSIST ON IE OR WILL NOT LOAD PROPERLY .
THANKS AGAIN
QUOTE(corsair_moran @ Mar 8 2007, 01:19 PM) [snapback]82553[/snapback]
Hi,
I got UT300R2U. I have 3 PCs each on XP SP2, each with one NIC. The 3 are connected via a D-Link Switch. Could you please tell me how to configure to share the Internet connection so that one computer has to manually connect for other 2 to be able to access the Internet?[/b]
QUOTE(seshu @ Mar 8 2007, 05:22 PM) [snapback]82581[/snapback]
^ the following link gives the configuration of UT300R2 for multi users :
http://www.calcuttatelephones.com/dataoneinstall/mu02.html[/b]
I always thought UT300R2U and UT300R2 aren't the same. Are they? :unsure:
^ UT300R2 has just a LAN port and UT300R2U has a LAN &
a USB port . I donot see any differences other than this ...
Hi FriendI have a problem in configuring my modem settings(smartax mt882). When I type 192.168.1.1 I can see only the summary page. But I could not see any left side pane i.e., settings of wan, admin, DNS,NAT etc.. I want to change my password. If I change the password in dataone website then again I have to change the password in my modem. But I can't find any settings on left side. I used Lan, USB but still the problem is not rectifyied. I have not updated any firmwares coz, I could not find any updates on the Net.I can access to Internet well at any time. I used web browsers IE6.0 SP1, OPERA 9.01, MOZILLA 2.02, IE 7also.Java plugin version 6 (checked also with 5.9). Well my O/S is WinXP-SP2, Norton Internet security 2k6. But the problem still continues using all above applications.My TCP/IP properties:IP Address: 192.168.1.100Subnet: 255.255.255.0Gateway:192.168.1.1Preferred DNS: 192.168.1.1Secondary DNS:61.1.96.71Help ME!Thanks In AdvanceBharat
Hi I m using home 500 plan.can tell me the detail procidure to schedule my download from 2 am to 8 pm nu hours.
just train your dog to wake up at 2 am and open bit torrent.......its funny how broadband is being rationed in our country. lol.just kidding, i think this issue has been dealt with in other posts....just search a bit under the BSNL channel.... but what if the electricity goes off in between ? or the connection goes down ? then how would this automatic login thing help?
Status
