BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
Hi all.. I am new to Hyd and I stay in Suryodaya colony,LB Nagar...I want to take a new bb connection.I applied for BSNL UL900 plan.I submitted an online application last week.I was not given any number to track what happened to my application.Well thts expected!!!So I called up the kothapet so called customer care centre..They are reluctant to talk but they after I pleaded they said I have to wait for atleast 2 months for a new broadband connection!!!:OI cant wait till then...I dont know what to do I called up Airtel as their website is showing LB Nagar in the areas where BB is available but to my agony I found that they dont have any coverage in my colony!!!I dont know if its some call centre's guy mistake that my application is rejected or the coverage is not actually there in my area!! What should I do now guys????Should I wait for BSNL conection..i.e., for 2 months or go for a temp. connection with Sify or othr providers??I dont want to pay hefty installation charges as I ultimately will go for BSNL!! Any1 from LB Nagar area plz respond if we have any other good option...
Generally how many days can I expect a BSNL BB connection???Any rough figure????I read some posts tht it will take only 10 days etc. but I was scared to hear frm them tht it will take 2 months!!!!!
lack of modems is one of the primary reasons the connection is delayed. see if that is the case with you. if that is the case, you can purchase your own modem and get the connection fast.
yes when i applied for MTNL connection the person at local exchange told me if i buy my own modem they can give me connection tomorrow(i.e. in one day) itself, otherwise he said it will take 1 to 2 months. and yes it took 2 months but then i had extra connection from local cable op so i was able to wait that long.
Hi.. I also Got The Home 500 Plan a few days ago. I called up on 1957 to check with the confusion of total transfer limit. Tha lady says the usage will include night unlimited hours.. But it will be deducted at the end of the month eventually. But I'm still scared to believe what these @!#!@ say... If any one has got the home 500 plan for over a month.. pls clarify if this is true...
@ Ragoon , as Sushubh said it is better to contact a higher
official at your Exchange to apply for broadband in person
and request for the early connection .
@ chetak , pls check your usage records on http://10.240.89.199/ .
It clearly shows the used data excluding night unlimited usage .
( see right most column )
Thank you guys for replying.I will try to meet the higher officials in the exchange...Hope my next post in this forum will be frm my home pc!!!
Hello friends, Iam new to this forum. Came across whil I was searching for solution to a problem. I had been using BSNL BB for last 8 months.. Now I have upgraded my hard disk (purchased new one of higher capacity), I want to configure BB in my new Hardisk. Can anybody tell me how to do this.. I am using Windows XP with SP2.My ADSL modem: Huawei SmartAX MT800.I tried configuring Lan connection as i took note of the IP details in my Older hardisk. Given below are the details:IP Address: 192.168.1.xxxSubnet Mask: 255.255.255.0Default Gateway: 192.168.1.1Preferred DNS: 192.168.1.1Alternate DNS: 61.1.96.69But I could not connect to Net. I need your help here.. Should Ihave to configure anything in the ADSL modem..? Thanks in advance.,Regards,Stallion.
^ how are you connecting to the net - that is is it thru a shortcut
on desktop or do you get the connection by switching on the modem ?
if it is thru a shortcut on desktop then you have to make a new dialing
connection for broadband . modem is configured in bridge mode .
if it is directly thru modem then modem is configured in PPPoE mode and
you have to check its settings thru http://192.168.1.1 .
this link might help you in configuring your modem : link
Status
