BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
Hello Seshu, I tried to install manually the manufacturer's driver, xp is not allowing me. It installs its driver. I dont know whether I followed the right method.. Can you please tell me how to manually install a driver after uninstalling the ethernet card..Thanks in advance,Stallion
^ pls try : Device Manager -> Network adapters -> your network card -> uninstallrestart the system , and when a new hardware found wizard appears select for manual installing of your cardmanufacturer's driver for windows xp .if the wizard doesnt come up and installs the previous driver files then after uninstalling , run setup file of your network card driver without restarting the system ...
Hello Seshu, I tried uninstalling the Device & restarted, but windows automatically installed the previous driver. I dont find any setup file in the driver floppy provided by the manufacturer.. Is there any other way to manually install the driver..Thanks in advance..,Stallion
when you check the details of the card you get an option to update the driver. driver files are usually shipped in the form of .inf files i think.
what does the following modem system log message means..Could not get oam_ping_interval from boot loader env Trying to retreive the value from Configuration oamPingInterval(20)(20)Valid Configuration Treestat successfull for /etc/resolv.conf.Resolver Polling Timer Started succesfully.NTP Polling Timer for DHCP Started succesfully.DSL Polling Timer Started succesfully.Firewall NAT service starteddel_iptable_rules : ppp_name not intact Bridge Created: br0updateall_servers : No children found for conn:Bridge Created: br1Bridge Interface Added: eth0Bridge Interface Added: usb0DSL Carrier is downdel_iptable_rules : ppp_name not intact -----------------------------------------please unchiper it for a layman...
Hello sushubh, I tried for updating the driver, But as I said earlier windows ends in saying that the existing asound driver is better than what I provide as manufacturer's driver. How to override the Windows with installing the devices automatically. Is there any settings in windows so as not to install the plug & play devices & it should ask for a driver..?Thanks in advance..,Stallion.
^ can you check the actual driver files being used foryour network interface card ( thru device manager ) ...I find that your driver floppy might consist of : (winXP folder)MTD80X.INF is the information file mtd80x.sys is the actual driver filemtd80x.cat is the security catalog we have to use INF file while updating / reinstalling the driverpls try again :1 uninstall the current driver for network card thru device manager .2 shut down the computer .3 physically remove the network card and put it back in the slot4 power on the system .5 Now new hardware found wizard might appear so that you cantry for the manual installation of the driver .
Hello seshu, I uninstalled the driver again. But this time I did not restart my computer. But I tried to scan for Hardware & it showed up a dialog box saying new harware installion. From there I proceded to install my driver through 'Have Disk' Option. Now successfully my Mtd80x driver. But i could not ping 192.168.1.1 or connect internet. Meanwhile one of my friend working as network administrator in an organisation suggested to do the following. Go to network places. Click on 'set up a home or small office network'. In the Wizard proceed & select 'other' in the 'select a connection method' menu. In the next screen, 'Other connection methods" select the option, "the computer directly connects to internet but i dont have a network' option. It will setup a network. Then restart th computer. I tried the above & successful in connection to internet. Thanks for all ur valuable informations.. Stallion
Status
