Hello,Thanks for the reply.Unfortunately my PC is located in a room wherein I cannot get through my Tel line !If I get a Type II modem from BSNL/or D-Link DWL G122 router and a USB wireless PC adapter will it work ?
^ you can take a type 4 or type 2 modem from BSNL if available .
And D-Link DWL-G122 is a Wireless USB Adapter for pc / Laptop .
pls see this link : D-Link DWL-G122
It works with DI-524 Wireless G Router or DWL-G730AP Wireless
G Pocket Router/AP .
i am presently using dataone with type I modem cud u tell me what all hardware (and jst everything needed from the basics) i shud get to use wifi connection with bsnl type IV or III modem for both desktop and laptop. plz help me .....
I have a Dual boot systemXP Pro & XP 64My dataone seems to be working fine with the 32 bit but isnt connecting with the 64 bit OSThe error code is 790 and it gets stuck at " registering on the network "
@ William , first decide on the wifi modem . And look at
the modem guides here : modem guides wiki
@ lucifershetty , we need your modem details and how
are you connected to the net (USB / Ethernet) ; is it
direct connection thru modem or using xp's dialer ? pls
give exact error message so that some one can help ...
i wud like to use the type II modem from the modem guide with 1 usb,1 lan and 1 wlan.
from the link Bharat Sanchar Nigam Ltd. the modem types differ.
anyway i wud like to have the modem with usb ,lan and wlan
from the figure in Quidway WA-1003A ADSL MODEM CONNECTION
they have shown at the back of the CPU the wireless lan.
what is that and is it provided by bsnl ?
are there any components that we have to buy personally other than getting the modem from bsnl ?
I have a BSNL provided Type I modem. connected thru ethernet. I connect through XP's dialer ( username / pw ). The error code is 790. The process gets stuck on "registering your computer on the network"
I am new to this forum. The title pulled me here. I want some help from you. I was airtel user all these years. Now shifted to BSNL. Yet to get the line. I have a PC and a laptop. Laptop used for office use (mostly VPN).
1) Rent the router from BSNL or buy new one ?
2) If buy, buy it from BSNL or outside market ?
3) If outside, which is the best WiFi router (cheaper too ??).
4) Do I need to take modem too ? (Currently I don't have)
Guys i am facing some strange problem these days! I have a type I modem and i am connecting through bridge mode but when ever i connect using ethernet line, the led starts blinking (i.e its not constant) and gets stable when the connection gets disconnected.The download speeds are pretty much ok but i want to know is this normal or some thing is wrong ?Krishna
@ William , WA1003A might be available from BSNL . you donotneed any other device to get internet connection to pc & laptop if you can get WA1003A . @ Lucifershetty , no fix is available at present for error 790 ...@ Ravi , if BSNL can provide a wifi modem cum router then it can be a best ( and cheap ) choice if you purchase it ...@ Krishna , as I understand it , your phone line needs to be checked by BSNL . pls give a written complaint ...
