BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
hai seshusome more doubts...........can there be a case that the desktop cannot enable wifi ? how do i know whether the pc can support wifi or not ? how do i get it enabled after getting modem from bsnl ? ie once i get the modem how do i get connected with wifi ? william
^ you wanted to connect a pc and a laptop to internet - right ...
Your pc is to be connected thru ethernet (LAN) port or USB port
and your laptop has to be connected thru wifi . in general , all
laptops have wifi connectivity and wa1003A can directly provide
wifi internet connection to your laptop .
pls configure your wifi modem as per the guidance available here
cud there be security or privacy concerns with wifi ? cud others in the neighbourhood use my wifi connection ? how do i protect my connection from others using it ? william
^ all wifi modems have inbuilt security . A passphrase
(like password) used to secure the connection . This
passphrase is to be entered in laptop to get the wifi
connection . It should be strong enough so that your
neighbors cannot guess ... once you get a wifi modem ,
you can see its security details in its manual / user guide .
more technical information available on wikipedia :
wireless security
WEP encryption
Wi-Fi Protected Access
have acute problem with bsnl bb home 900 ul. all the day time i am facing problem like discovery OP msg in line state. my SNR Margin remain between 5-10 in downstream. can any body tell me in detail about Discovery OP and SNR Margin. how SNR margin is controlled. Even when connected the speed varies with every few minutes from 500 kbps to 900 kbps & for a moment it disconnect to reconnect. so it is almost no connectivity kinda..
^ your phone line needs to be checked for earthing / lose connection by the BSNL linemen . pls complain in written .(if possible , meet the concerned official at local exchange) If there is no problem with phone cable then request to change the allocated port at the server .
hai seshu with type I modem i cud connect both laptop and desktop with lan and usb connectons repsectively using intenet connection sharing ? but with type II modem how do i connect laptop and desktop simultaneously with wifi and usb/lan or isnt that necessary ? william
^ ICS is not necessary at all if you have the wifi modem having two different ports - a wifi port to connect thelaptop and a Ethernet port (or USB port) for desktop ...
Status
