BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
i Am using BSNL broad band Type I modem - UT-300R2U - UTstarcommodem hav 1 USB + 1 Ethernet portmy self and my roommate using both at a time ,,both have Dell with WINDOWS VISTAi have installed the USB driver for VISTAand when i connect to USB after some time it is getting disconnected automatically and makes the PC Hangif you could provide me some help i ll be very much helpfullvimalbangalore
^ just a few queries here : what happens to Ethernet connection when USB isdisconnected ? if Ethernet works without any problemthen can you swap the connections to check whathappens ... and where did you get the Vista drivers ?
Hi Seshu, i've a touchtel modem from my previous airtel bb connit has single usb port no ethernet or wifi can i use the same modem for getting a bsnl bb conn instead of goin 4 a Type 1 modem? i tried searching this thread n found a similar query from raj_2007 which went unansweredthis is from Raj's post"Now i want to buy a USB Powered DSL modem (so that i can use during electricity cuts)My friend also has this spare modem======================================Modem Details:USB ADSL Modem: R. B. COMTECX7005QVer: 0.4Date:AUG 2003XAVI Technologies corporationModel Name :Xentrix X 7005Q======================================He told me that this is an Airtel modemHave you used this modem in connecting to BSNL and if yes what do we need to do this make this work?" (i dunno the type of the my touchtel modem so u can take this as a reference) Thanx
^ yes JayZ , we can use any ADSL modem to connect
to BSNL's Dataone broadband . we have to use correct
settings for Dataone (VPI , VCI , DNS , etcetra) .
you can see this link for guidance : xavi modem
if you can tell us the exact modem number then we
might be able to give more information if required .
Thanks a lot 4 tat info Seshu,
bout my modem, nothin is written on the box except "Realtime Systems India Ltd"
after a lil googling i found this,
"The default USB modem being provided by Airtel is one manufactured by Realtime Systems, which runs on a Conexant chipset. "
from Airtel [Beta] | Quillem.com
on the realtime systems' website only thier other products r listed
n not the one they manufacture for Airtel
Realtime Systems Limited
this being the case, are ther any general settings for configuring the modem?
Hello Friends
I have tata indicom 2MBPS connection :yahoo:
I will go also bsnl home plan 500.
Can I use tata indicom router for bsnl connection?
can is it possible? and how? is there any configuration setting.
tell me your opinion friends
hi seshu is it true that ethernet connection gives better download and upload speeds than usb connection from the same modem ? do we get the same speed with wifi connection as well ? how can we improve speed in all cases ? william
@ JayZ , I have seen the given links and am sure that
it works for BSNL broadband . just configure it like xavi .
post here on the forums if you have any problems .
@ Ravi , Tata Indicom works on ADSL technology .
Its modem can be configured for BSNL broadband .
main configuratin setting : pvc --> 0 & vpi/vci --> 0/35
@ William , yes , Ethernet connection is better than
USB and wifi . Ethernet is also stable and reliable .
wifi connection speed is somewhat less than ethernet
connection's speed . it can be about 10% less (depends
on various factors) ... we have to ensure that other
devices (like cordless phone) do not interfere with
wifi connectivity . we need not take much precautions
for ethernet & USB connections .
it has been observed that keeping modem / router
just above computer's CPU affects the performance .
hence we should use a separator (like a wooden
block) in between modem and CPU ...
hi this is prasanth, i hav home 900ul plusi connect thru brigde mode..UT-300R2U modem thru ethernet porti would like to know ,if i reinstall my OS,then creating new internet connection (using new connection wizard) will be sufficient for resuming internet connectionor do i need to do any thing extra than this pls help me outmy 2nd query is wat r upload speeds in home 1000 planhome 900ul really very down on upload..if i shift to home 1000 plan, do i need to wait for a min period of one month for again reverting back to home 900ul....
Status
