BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
I just got a new connection and this worked for a day. Now it does not work and I tried all possible checks on the configuration. Don't know what to do.TTRaja
hi ttraja, did you filled only online form or did something else also to get the connection?
I have a Starcom UT-300R2U router, that supports USB and Ethernet connectivity to a PC. I have an 8-port switch and 2 PCs running XP, both having ethernet ports. How do I get both PCs on the Internet with this setup ?I know one way is to connect one PC via USB to the router and setup a LAN using ethernet with the other PC, but I'm aware that USB is not really an ideal way to connect to the net so I'm looking for better options. Can I have one PC using the USB connection of the router and the other PC using the ethernet connection ? What do you suggest ?
hello mr helpful gentleman i was very delighted to find ur thread... im using BSNL BROADBAND 500/- home plan since past 5 days... i have problem wit eating up my usage till 1.534gb/0.545(excludiing nit) but i wunder whn hav i spend this much usage.. bcoz i didn't spend much time infront of pc... i changed password 2 times.. no use... i been worrying abt my usage... what shud i do now for pulling it back to normal.. any help ?? thnks
^ please check your system for viruses/trozans ...
use zone alarm to check if any malware/sw is connecting
to net . and keep automatic updates (including os) off .
make sure to use free net between 2:10 and 7:50 AM.
that is to say always connect after 2 AM & disconnect
before 8 AM .
your day usage could be normal (approx 110MB per day)
if you are visiting sites with rich multimedia content !
visnbm
__________________
Home : WinTrikX
Moderator:
A commercial link allowed in this forum ? wants Rs 200 as license fee.
By the way this thread has become all purpose without any definite subject !
as long as you are here to help, can you tell me if you can use a voip device when your router is in bridge mode? I have been asking this all over the place, never got any real help :)
thnts wonderfun to hav u here.. im using BSNL braodband 5oo home plan... i got tis on last 18th july.. but thing it's wasting my usage.. despite I was using firefox with add on:flashblock for disable flash contenti didnt downloaded flash player software yet, imagelikeopera for disable images, and noScript.. but i sure im not using much either morning and night at unlimited time.. but it is showing like below: Total Volume(GB):2.038 Sum Traffic(GB) Excluding Night Unlimited:0.636 so tell me what is this mean... hw much i hav used till the date.. and im using Kaspersky internet security suit. but i disabled its automatic updates.. and Microsoft also so pls guide me about my usage.. and hw much i hav used according given details. ur reply wud be appreciatble.. thnk u
Status
