if you are downloading something do it after 2:20AM and shut it down before 8 i think that should solve the problem. I had the same prob and thats the advice i got and my prob was solvedif you are downloading something do it after 2:20AM and shut it down before 8 i think that should solve the problem. I had the same prob and thats the advice i got and my prob was solved
