BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
hey dudes---i got an SMARTAX MT841 modem n I donno how to configure the wireless connection---plz help me out with this
Quoting from other community forums :
This is the step by step prodcedure on how to configure BSNL Type IV (MT841) modem for autodail and wireless setup.
First do not insert the WLAN card in to your modm. connect it with supplied LAN cabel or via usb.
Go to your computer eathernet connection setup and change the ip of your eathernet card to the following.
IP Address : 192.168.1.2
Subnet Mask : 255.255.255.0
Default Gateway : 192.168.1.1
now in you browser windows open up the configuration screen of mt 841
in the left side you see the wizard from basic drop down list select connections. Left side you see PVC0 to PVC6 now you only need to change the value of PVC0 to dial up the connection automatically with PPPoE setup. but some how you can not edit the connection of PVC0 by clicking the note icon on the configuration screen. it only let you change the settings for wich the PVC is created and let you delete it. so you need to delete all the PVC in the list. Stat from PVC6 press notes icon and delete.
Do the same process for PVC6 to PVC2 and PVC0 do not delete PVC1 untill you create new PVC.
now press the new button and create new PVC specify following parametere in the PVC
WAN Type : PPPoE
VPI/VCI : 0/35
Encapsulation : LLC
Default Route : Enable
User Name :
Password :
use DNS : Ebable
now click on apply. It will show new PVC and it display it as PVC1 now delete PVC0 from the list and start create remaining PVC for your connection by pressing new.
All PVC shoud have following property.
Wan Type : Bridge
Encapsulatino : LLC
and for VPI/VCI follo this steps
PVC1 : 8 /35
PVC2 : 0 /100
PVC3 : 0 /32
PVC4 : 8 /81
PVC5 : 8 / 32
PVC6 : 14 / 24
now you have created all the PVC's with you dialer configured at PVC1
go to advanced select Firewall and select enable.
go to DNS selct Ebable and put following value in the dns
Primary DNS : 61.1.96.69
Secondry DNS : 61.1.96.71
save your change and reboot the router.
after reboot you should be automatically connect to the internet without dialing PPPoE dialer from the computer. now turn off the router and connect the WLAN Card to the router and disconnect the lan cabel from the modem and computer. after you see the WLAN light on in the router stat your wifi connection from compuer or modem to search for availabe network and you will be connected to the net. [/b]
QUOTE(mpartha @ Jan 3 2006, 03:48 PM) [snapback]38185[/snapback]
Hi,
I have a Type IV Modem - MT841. I have configured the Lan - Ethernet (all 4 ports work) as well as the USB port and they work fine. However, I am not able to connect on to the WLAN using the Wireless connection on my Laptop.
Do you know what hoops I need to go through to set up the Wireless connection?
Thanks!
[/b]
Please tell me how u hv configer the same. My connection is BSNL-Startup, 256Kbps
Thanks
DasA
Hi I got it frm the bsnl's site on tariff for new plans:
" For Home Plan UL 900 Plus: Telephone Rental per month- Nil, Free Calls- Nil,
MCU charges per Pulse @ Rs. 1/- shall be applicable. The calls shall be charged
as per pulse rate of BSNl Bfone General Plan. Security Deposit and Installation
charges as applicable for Local/STD/ISD shall be taken from new customers"
Kindly let me learn what does MCU charges per Pulse @ Rs. 1/- shall be applicable mean.
Means how is it going to affect the bill.
Thanks inadvance.
Manu
@DasA , the answer to your query is already available
just above your post and also at another thread . Pls use
the search feature . If you have any specific problem then
do post here . someone will respond .
_________________________________________________
@manu , MCU charges per pulse is for the phone calls (voice)
made from that phone . Free calls are Nil . Each and every call
is charged at Rs 1 /- per the unit .
QUOTE(seshu @ Jul 29 2006, 08:25 AM) [snapback]56962[/snapback]
[/b]
@Seshu
means MCU charge has nothing to do with internet usage. Then can we be sure that the bill for internet use will not exceed Rs. 900/ in any case?
@manu , if you donot use the phone for making calls
then on dataone 900+ plan , your monthly bill will be
Rs 900 + service tax + ed. cess + modem rent (if applicable)
@anushka
to configure Dataone on win98 .
first of all there are 2 ways to connect .
1. using PPPoE dialer
2. using inbuilt Modem dialer
1. in case 1, your modem will simply act as a modem and not block ports
for you and hence no security.
the procedure required for this kind of thing is given in detail at
http://www.calcuttatelephones.com/dataoneinstall/menu.html
you need to download the PPPoE dialer for win98, and also the PATCH for
the PPPoE dialer for win98, both are given on the above site. read the
instructions given there and you are ready.
2 in case 2, your modem will act as a router blocking most of the ports.
many experts recommend this router action.
in this way, you need to set your lan card some IP addresses,
first do http://192.168.1.1 to access your router
(if you have not changed it)
and then in there goto WANsettings,
in that select PPP, connection type : PPPoE,
enter your dataone username and password,
click APPLY, save,and the modem will restart in 2 minutes.
now you need to configure your network card settings.
right click network neighbour hood > properties,
then select your LAN card's TCP/IP Properties,
in there enter the following :
IP address : 192.168.1.2 (can be anything in the range 192.168.1.*)
but except your routers IP )
subnet : 255.255.255.0
gateway : 192.168.1.1 ( ip address of your router)
dns1 : 61.1.96.69
dns 2 : 61.1.96.71
click APPLY, OK, it will ask you to reboot your PC,
and after the reboot, you will have internet
whenever you switch-on your modem . [/b]
QUOTE(seshu @ Jul 29 2006, 03:43 PM) [snapback]56973[/snapback]
[/b]
Thanks Seshu
hey i get DisConnect Once in a day ??? Y ... n i Use..D-Link Modem..N packge is UL 900 ...n USin...xp Sp3....unoffical... created by my frnd..Im frm Hyd..Last Week i got BSNL Broadband....waitin..for Reply..
Status
