BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
^ yes , I face atleast one disconnection every day .often when there are heavy rains .I was assured that the phone cable will be changed when they get a bundle of new cable ; I understandthat the server also facing some problems ... it will beimproved ... when - they donot know !
Hi!Thanks for the offer to help!I have been using bsnl broadband with the MT882 modem for the last six months. Recently I decided to get a wireless modem from them. When the WA1003A came, we tried to install it in my comp. Initially, they asked me to install the USB port from the installation CD. This gives an error message:"Incompatible version of the RPC stub. Error no 0X80070725"What does this mean? Is there a compatibility problem in my system?Thanks,Swati
^ Hi Swathi
Look at the relevant info on the following Link
http://www.calcuttatelephones.com/dataoneinstall/menu.html
I couldnot understand why the installation of a " USB port "
was required for your system !
If you are using the modem thru USB port then you would
require the USB Drivers Installation . However I feel that
LAN connection is better than the USB connection .
QUOTE(kambui @ Dec 17 2005, 01:36 AM) [snapback]36111[/snapback]
Well I really want to make Dataone section of this forum popular.
I can provide you all with any help .......Now y ask me? Answer: 1) I think I am the oldest in this connection 2nd Feb 05 ( there may be other but i don't know any)
2)I have dealt with 6 types of dataone connection ( even a @ 2MBPS one) thats why i have see all types of modem supplied by dataone.
3) I am a hardware professional ( bit of networking)
4)BUT above all I will stick to this connection in future :D
Any new or old dataone users can contact me through this forum by posting and i will try to answer your queries.You can also PM me but i prefer posting because every one can see it then.
Please don't ask any illegal favours. I had some situation where users were asking me USER ID's and PASSword of other user.....PLZ DON"T do that!!!
@ Suneeth , pls donot post the same query atdifferent threads . only one place can serve thepurpose . your problem can be due to one ofmany factors . And you need to give more details .see the other thread started by you .
Hi, I would like to know whether it is possible to use a different username and password to connect to the net using dataone than the one that is provided to you by bsnl. I'm currently using home 500 plan and i have the username and password to my friend's 900ul plan connection. But i'm unable to connect using that account when he is not using it.
^ @sudeepp, Unlimited plans at the most places are bound to specific phone numbers . i.e. the unlimited connection works only thru that particular telephone . hence it can notbe possible to use this plan thru other phones .
Hi frndss plz tell me how can I use my dataone connection as dial up broadband connection, in which I should enmter username or password everytime for connectivity. What all changes I have to made in my SMART AT 882 modem and in Network Connections. My OS is WIN XP. n what wil be the username n password for connectivity through dial up connection.
^@sunny,
you need to enter into your modem's console ,
select rfc bridged for the wan connection & save
it before proceeding further . Assuming that you
are aware of the procedure .
configure your network connection :
Set your computer's IP address to 192.168.1.xxx
and subnetmask as 255.255.255.0
you can choose any number from 2 to 254 in place of xxx.
Set default gate way as 192.168.1.1 because ie router's address.
Set DNS to Primary: 61.1.96.69 Secondary: 61.1.96.71
Now use win xp's dialer to choose your NIC ;
give user name , password ;
and phone number is 0 to dial broadband ...
here is a MS link giving simple instructions :
http://support.microsoft.com/kb/283070/en-us
And there is no need to post the same query at
different threads . one is enough ...
Status
